scarda
February 17, 2023, 3:21pm
#1
Hi
i’m trying to add a gitlab project integration (i’m using oauth authentication), but when i’m saving it throws an error:
Something went wrong, please try again.
Looking on the problem console, it shows the following problem:
Action: Add Branch (Crowdin Service)
Message: This action is not available for account subscription plan
but then on the remote repository the branch was created
someone could help me?
Dima
February 17, 2023, 3:48pm
#2
Hello @scarda
You’re on the free plan, right? I see you already have 1 branch in Sources, please remove it before adding a new one via integration. More info on the matter:
Hi all. Yes, as @TiroliTemar said, the Free plan is not the same as Free Trial, and due to the limits, only 1 branch is available for this subscription tier. With proper management, this should be enough to work on simple projects. Here you can read more about Version management → Version Management | Crowdin Documentation
If you need more branches, I’d suggest you check out the Team plan, which offers unlimited branches → Plans, Pricing, and Free Trial | Crowdin
Alternatively, you can apply f…
scarda
February 17, 2023, 3:59pm
#3
Thanks for the reply,
I thought that being the same branch it connected automatically.
Now works Thanks
