I’m trying to use the Figma plugin within design files. When I try doing so it loads for at least 30 minutes before I can access the strings, how can I speed this up? Disconnecting is no possibility because it connects automatically and sends me to ‘Strings’.
Hi @productteam,
It can happen if there are a lot of strings in the project. In such a case we recommend waiting for strings to be loaded and after that, you can use the file filter to work with strings from specific files only:
