Hey, I’m using Webflow integration to import strings etc. It’s worked well so far, but now when I’m trying to import from website, it says it ‘failed to authenticate’ and that I need to ‘check the expiration of the token’.
I’ve updated the API token, but it still gives me the same error. What do I need to do? Is there and issue with the API?
If so, probably you to clear browser cache and re-install the application using new token from the Webflow, but the most powerful one, like owner-scopes level.
Had the similar staff but with JS Proxy - well, not sure whether totally similar, but in Incognito mode it worked, so I’ve update browser to latest version and wiped up the cache so all worked.
This google (I use Chrome) should think about update policy. I never turn off my laptop, just close it, so it gets to sleep or so. As a result my browser was 7 months outdated which is incredible
