We only need API access for build automation; any regional limitations we should be aware of? Thanks in advance:)
Hi @Multipass!
There’s no inherent regional restriction enforced by Crowdin’s API and it’s generally available from anywhere, as long as you can connect to api.crowdin.com (or your company’s Crowdin Enterprise domain)
The only potential limitations are related to local network setups:
- If your environment blocks certain domains, you’ll need to ensure
api.crowdin.comis accessible. - If you’re behind firewalls, proxies, or regional internet blocks, those might affect API availability, but this would be on your side, not Crowdin’s.
You can find detailed information about our API here:
