I just configured a new Machine Translation engine and I don’t see it showing up in the web UI. Is there a way to test if it’s configured correctly? It would also help to know if there’s a lag between configuring an engine and having it show up in the web UI.
Hi @kueda I assume you configured it under your account while projects you work on are created under a different account. Please ask the project owner to set up mt from their account. After that, suggestions will be shown and you will be able to test the mt
Excellent assumption! I enabled it under the project owner account and MT suggestions showed up immediately. Thank you!
