I need to connect my Gitlab repo to the project. I know it’s better to add translations directly to the Crowdin project, but I already have some translations on the repository as well
So my questions are:
Is it possible to upload the translations from the repository to the project using integration?
Or should I manually add the translations in Crowdin?
I have also some translations in Crowdin project? Can I keep them? Or they will be removed after integration set up?
specify the path to the folder with translations in integration settings - translations from your repository will be uploaded to the project then
the old translations will be saved in the project as well. there will be just a few translations for one string after you upload the translations from your repo
