The folder “/Plugin/Models/Projects” doesn’t have a metafile in the unity-plugin, which causes errors in unity on mac.
So please add a metafile to the folder in the next unity-plugin update.
Hi @Maskerades ,
Could you please share some more details on the errors it causes? Perhaps you could send some screenshots?
Hi @TaniaM
The error it produces is this one.
Asset Packages/com.crowdin.unity-plugin/Plugin/Server_API/Models/Projects has no meta file, but it’s in an immutable folder. The asset will be ignored.
It appears every time you open the project or code recompile in unity.
Thank you for all the details! Already passed everything to our developers to fix the issue as soon as possible. We’ll let you know when it’s done.
We created a task for a fix (57939). Once it’s released, I’ll let you know.
I’m happy to inform you that a new update has been released for the Unity plugin. ![]()
The problem should now be resolved, and the plugin should work correctly on Mac without causing any errors in Unity.
Please feel free to test the update on your end!
