Unique File Formats Error
Hello,
I am a free plan user and I almost always uploaded .txt in my projects. Today, when I was setting up a new project and trying to upload a .txt source file, Crowdin gave me this error.
I tried uploading a sample .txt file with only one line and I still get that same error, and cannot upload any new source files. Is it an error on my end or is it something system-wide? Thanks!
Hi,
Free plan has a limitation of 3 file formats. This means you can use simultaneously 3 different formats. For example, if you already uploaded MS Word (.docx), MS Excel (.xlsx) and PowerPoint (.pptx), the 4 format (.txt) would be skipped.
Hope this clarifies the situation!
Hi Dima,
Thank you for your insightful reply! However, pretty much all of my projects consist of .txt files. I reviewed all of my projects and, indeed, I have also been using other formats like .rpy, .utf, and .po alongside .txt. Thank you!
Just did some magic :magic_wand::mage: from my side, hope it solves the issue :slight_smile:
Hi Dima,
Thank you so much for your magic! The problem is solved :pray:t2::heart_on_fire:
