Hi! Our team is unable to add new plural strings using the Crowdin Editor.
Import from file and export to .stringsdict works correctly.
We can view the strings:
The file does appear in sources:
But not when trying to add a new string:
When selecting “Plurals” no files appear on the right side and text fields are disabled:
What should we do so the file appears in the “Add String” popup?
