Hi,
I’ve invited a Translator to our project but they cannot access the project’s glossary. They don’t see any glossaries on their Glossaries page. I can access the glossary and it is listed as a project glossary in the Project Settings.
Thank you.
Hi,
Thank you.
Hi @ravencontrols ,
You may define the access to the glossary for members in the Project settings > Privacy:
Hi Natalia,
Thank you for getting back to me. I’ve updated the Glossary access settings to Full Access:
Unfortunately the invited translator is still unable to view the Glossary.
The account is a Pro subscription.
Thank you,
Jock
Sorry for the confusion! Once this option is enabled, the translators will be able to add/edit/delete terms directly in the editor (not through the mentioned Glossary section), kindly refer to the screenshot below:
Hi Yuliia,
Right, translators can’t see the actual Glossary but terms in the glossary are highlighted in the editor.
Thank you,
Jock
You’re always welcome, my pleasure to help! ![]()
