After pressing “translate all” and then “save all” in AI window.
Also, earlier, pressing “Transalte all” in AI assistant window, only not translated strings were translated. Now AI translates already translated strings again.
Hi @audrius
Thank you for reaching out to us.
I’m checking this with our team and will get back to you once I have any update,
Hi @audrius
Can you kindly tell me if you are using Crowdin-managed AI or your API key?
If it’s your key, then it’s quite possible that the limits are too small to proceed.
Please check the AI provider configuration (token/request limits).
I use my own API key and it has no limits.
Also this mentioned problem shouldn’t be API key related.
Earlier, pressing “Transalte all” in AI assistant window, only not translated strings were translated. Now AI translates already translated strings again.
Hi there,
If your API key has no limits and there are no AI provider request limits, you can check project logs to see the detailed system response (tools → service logs).
In addition to this, if you could provide the project ID or URL to specific strings where this issue is occurring, I’ll be able to check via my database what caused it.
You can email us at support@crowdin.com or reply here.
Too Many Requests happens when pressing “Save All” in AI assistant modal.
Sorry for many posts, but as a new user I can embed only one image per post.
Project soranoracom, Tools → Service Logs is empty.
Hi @audrius
How many translations are you selecting/choosing at one click? Your token can have an API call request limitation. While working in the Editor, a common practice is saving suggestions while reviewing them one by one.
If you’d like to pre-translation the project, please do it with a pre-translation via AI option:
I think I know when it happens.
Now there is a bug, when pressing “Translate All” in AI assistant, translations for already translated content are made again (not just for not translated). Crowdin sends already translated strings to AI to translate again. Bug.
When translation is done and “Save All” is pressed, Error #429 happens, when translation is set to already translated strings again.
Hi @audrius !
Can you please share with us some strings examples which were translated again by AI? Does the issue persist in Soranoracom project?
Thanks in advance!
