Hi there,
I’ve got a sync issue using Bitbucket integration referencing the ‘crowdin.yml’.
It says: “Unable to get content of remote file”.
Response code: 502 Bad Gateway
Is there any way to fix this issue?
Hi there,
On the “Free” plan you have 1 integration and only 1 branch available. Also, the BitBucket server is not available for this tier. In order to connect another repository you will need to first delete the existing one + delete a representative branch in the content section in Crowdin.
Probably your code is open source, in this case, you can apply for the open license (it has unlimited branches):
