Strapi Integration - Full Fields Not Coming
Im trying to integrate my Strapi to crowdin. Did everything right as per the tutorials. Gave Full Access API Key.
After Syncing, its only showing ‘Global’ & ‘Page’
But i have several other Contents like, blogs, articles, authors which are not synced. Pls Help
Hi @devbscnews, could you please kindly send us the screenshot of your settings in the Strapi integration?
Hey, my bad. I had not enabled internationlization on those fields in strapi. Once it was done, those were synced.
But now my translations are stuck in 0%. None of them are progressing.
Hi @devbscnews
The system will not auto-translate the incoming files unless you activate MT/TM/AI auto pre-translation in the project settings.
Please send us the project ID via email (support@crowdin.com) so we can review everything from our end and provide you with setup recommendations :slight_smile:
