We are using strapi for content management and want to improve translation management with crowdin. After installing the Strapi integration and entering URL and API token, there is no error message - and no further activity; only a running circle. Any idea, what is going wrong?
We are on the free plan during this evaluation.
Note: With same token and URL we can access the conten with Postman.
Hi @mhillmann ! Could you please contact support@crowdin.com and share the project link + video-recording of the behavior you face?
Ok, I wrote an email to the support with screenshots and a demo token to my test server for reproducing the behavior at your side. I will update this ticket in case others are facing similar issues.
Dear @mhillmann thank you!
Just for reference for other readers:
Fixed in our firewall settings. We must disable two security measures in the firewall: “Static URL Hardening” and “Form Hardening”.
Now it works like a jarm
