Storyblok auto-sync settings
I’m using the Storyblok integration for Crowdin and want to enable “Auto sync”. We have a couple of issues though:
  1. When syncing Storyblok → Crowdin, the integration pulls strings from my storybook drafts, and these might not be ready to translate
  2. When syncing Crowdin → Storyblok, the integration publishes every story, so anything unpublished becomes published when syncing.
Would it be possible to:
a) Only pull from published stories?
b) Only publish stories that are already published?
In advance, thanks,
Cheers,
Kevin
Hi kevinandersen
Thank you for your message!
At the moment, we don’t have the mentioned features available. However, we’ll discuss this with our PM to see if it’s possible to implement them. We’ll let you know as soon as we have any updates :slightly_smiling_face:
Hello Kevin,
We’ve checked with the team and technically it should be possible to realize this feature. We’ve created an internal task (55119). Once it’s done, we’ll let you know :slight_smile:
Hi @Dima and @Olena, thank you so much for your response and help in getting this feature implemented. This will really help our workflow.
@Dima , just wanted to follow up and ask whether there are any updates on your internal task 55119?
Hi @kevinandersen
Yes, the task was released, and now integration recognizes Published and Draft statuses. You can check it in the integration settings (wheel button).
