Sender.net integration
I’ve added the sender.net integration to my project but it’s not appearing in my integrations
Hi @Gez
This integration works with file-based projects only. If it’s not shown in your project integrations, and you haven’t limited app access to projects, please create a file-based project instead.
Hi there, thanks for the reply. I figured this out in the end - I was using a strings based setup.
