Hi
In crowdin api v2 (javascript client) auto-tagging works perfectly if I use “add screenshot” call, but when I update existing one with “update screenshot” it does not. Whatever I do I always see the error response that code is not done. Is it expected?
There’s no script for it. I mean, this option is not supported right now, that’s why you have the error. At least it comes as conclusion after reading Crowdin’s knowledge base.
Google finds an issue in Github, seems it was reported in November autoTag on existing screenshots is not supported · Issue #204 · crowdin/crowdin-api-client-js · GitHub
And it seems this API is kinda open, so if you have time I suppose you can contribute and add this screenshot tagging option as well.
