Hi, I try to connect the Github repository but it’s not listed in list of available. I connected another repository in another project with same account, and I’m the owner of both repositories. What can be the issue?
The repository is private, right?
As far as I can see, you have an approved open-source license, which means you cannot translate private repositories. This is the reason why you don’t see your private repository listed.
Try changing the repository visibility, should definitely help.
yeah, it worked, thanks!
