Looking at adding a label, and seems there’s not register sensitivity. Using this call API v2 Reference
to add “TesT_LabeL”, but receive error bad response. In a project I already have “test_label”. Tried by project UI, same result. How to turn on case register sensitivity, so Test ≠ test?
It’s a default one, worked in that way as long as I can remember. Not a bug, a default system behaviour. Same should be with export and branch naming, at least I think so. You can submit a feature request, but I think it’s a minor one that would not obtain enough votes to go into production.
