I’m having a difficult time finding the membership docs for public projects. I assumed anyone could contribute, but do translators actually require explicit invitations?
Thank you!
Eric
Thank you!
Eric
Eric,
Public projects are visible to everyone, and searchable via search engines and Crowdin search. You can restrict access to specific languages after the project is created (the user will need to send a join request before starting actual work).
You can find some public projects here to see how it works:
Thanks. You wrote:
“You can restrict access to specific languages after the project is created (the user will need to send a join request before starting actual work).”
To my knowledge, I’ve not explicitly restricted access to specific languages for my own project. Is this restriction applied by default whenever I choose the languages for translation?
Thanks. I am able to see the Join button when I browse other public projects.
Is the Join / Invite workflows the only way for translators to participate?
It’s about moderated project joining (Users can join a project only after a request is approved).
So when you click Join on a specific language, this is sent to the manager/owner for review and approval.
Yes, it’s the only way apart from dedicated crowdsourcing workflow which is available only in Crowdin Enterprise:
