So, I connected the DeepL for test and run some pre translation, and quality is great, but now the pre translate doesnt work, like it brings 0 suggestions although in Editor I see suggestions from DeepL. What can be a problem?
Most likely, the rate limit of characters is overreached. DeepL offers about half a million, please check whether you’ve already used it.
@DuuanVanVaagh suggested a few others engines, you can connect one of them in addition to DeepL. If pre-translate with new one works, then it’s 100% limit overreach.
