Postmark integration isse
Hi
When i try to login to postarmek it throws 401 error
Thanks
Hi @xavicabot , could you please kindly check if you’re logged in Postmark itself when trying to connect integration to Crowdin? Also, could you please kindly check your permissions that you have in Postmark?
