Hi, is it possible for Crowdin to support the i18next JSON v4 format for plural associations?
They use a suffix pattern, not a nesting pattern.
@JoseMariaDeVeer how do you upload files?
Recently Crowdin’s team added support for all plurals types (formats).
Maybe you don’t indicate the type of file like “i18next_json” during upload via API or CLI?
With UI upload it possibly may not work (not sure, never tried) - system probably can’t detect format like i18next by itself without specifying that (and because specifying is possible only via CLI or API, personally I use them)
Or use this format (supported via UI)
“one”:
{ “msg”: “{Files} file” }
“other”:
{ “msg”: “{Files} files” }
