Thank you for bringing this to our attention. I suppose it might be related to how the system handles character encoding during updates, but I need to double-check this with our development team.
In the meantime, you may want to avoid using quotes in comments or consider using different characters that do not require encoding.
I will update you once there’s any feedback from the tech team.
