Hi,
I made an app that is published on GitHub. A customer reported that a piece is not translated. After investigation I found that a RESX file is not translated at all.
Looking at the Branch Configuration in Crowdin, I see the file appears (see below). But in the Source tab, the folder appears and says there’s nothing to translate.
I addressed the issue by manually uploading the file to the Sources tab. But I’m curious what could explain that it was not there. I do not recall removing it myself.
