I am importing already translated content into 14 languages for a structured android xml based schema.
However from github import, almost loosing 30% of the translated content in the project. Its random for each language.
Uploading manually for each file with translated content also doesn’t help and it misses the exact same keys.
Maybe the translations match with the source text or the source strings are hidden, this is one of the options. In such cases, if translations are imported via UI, API, or CLI, there are additional import options
To check your case, can you please share with us the source file and the translation file in one language so that we can test from our side and tell you the exact reason? You can share files with us by sending us a message at support@crowdin.com
Experiencing the same issue with Android XMLs, it seems like strings with XLIFF tags are skipped during upload regardless of the import options in UI/CLI.
