Hi, I’m investigating Crowdin service, and I’d like to do some tests, I’ve checked the UI, checked CLI documentation, but didn’t find the staff I’m l4:
I want to add a few stings with the same label and same visibility parameters, they should be hidden. How to do it best?
Hello @TailorW
Hope you’re developer (a little bit :))
This should be possible via API, I guess this command will work pretty good for you:
https://support.crowdin.com/api/v2/#operation/api.projects.strings.post
By the way, their API is pretty good. I’ve spent about 40 minutes setting a circle action cycle, but now all I need to do is to press 1 button and all my translations are instantly downloaded + sources updated + reports generated and downloaded. Sounds good right?
