I have found a case where the Crowdin Markdown parser does not work well.
It can be found in Crowdin Enterprise , 30-dplyr.md.
In the 30-dplyr.md, the source text
is replaced to
in the translation.
In our project, the replacements “```” and “````” are at issue.
Does anyone have any ideas to solve the above problem?
Tania
August 19, 2024, 11:24am
2
Hi @kozo.nishida !
Would you be so kind to attach your source file and the file with translations so we will be able to check everything from our side?
Thanks in advance!
By the way, the reason I put the image instead of the Markdown text is because I could not find out how to display the original Markdown in this text box.
Olena
August 21, 2024, 7:27am
5
Hi Kozo,
Thank you for sharing details,
We will fix this behaviour. Meanwhile, as a workaround, you can use the Regex app to replace “````” with “```” on export.
(The internal task number for the support team to track the issue 50949 )
Hi Olena,
The replacement “````” with “```” on export seems to work well.
But the replacement circled in red in the attached image did not work.
Any advice on how to get it to work?
Tania
August 22, 2024, 6:28am
7
Hi @kozo.nishida !
Let us please check this from our side!
Will update you once we have any news!
Tania
August 22, 2024, 12:01pm
8
Hi @kozo.nishida !
Coming back to you as promised! Could you please try to set the Regex rules as on the attached screenshot and let us know about the result?
Thanks in advance!
Hi @Tania
I set the Regex rules as on your screenshot.
It seems to be working well!
Thank you!
