Per the title. Project link: Crowdin Enterprise
We would like to be able to mark some words within the same source as more important than others, or even split them apart based on a criteria other than hiding or sources.
We’re considering merging some of our source files in the repo, as the contents under words
and sandbox
have the same metadata and fields for translation. This would make maintenance significantly easier, but we’re worried it would make crowdin nearly impossible to search through given our usecase.
We keep track of a dictionary for Toki Pona, and Toki Pona only has 120-130 words depending on who specifically is asked. The definitions of these words should be given highest priority. However, many words exist outside of that core set, ranging from being used by some 60% of the community to barely 2% of the community per our surveys. These remaining definitions are worth translating, as these words are either in use or relevant historically, but are far less important the core set. The aforementioned “sandbox” group is an even less relevant group, primarily tracking experimental, one-off, or previously recognized and now unrecognized words below 2% usage. These have little to no priority to translate.
Is there any way mark specific strings as more important than others, or divide them by a criteria other than their source?
