Mailjet integration not working
I’ve set up the integration correctly, but when i try to sync a template from Mailjet to Crowdin, I get:
Sync files to Crowdin Failed
Finished with errors. See error logs.
I don’t see any error logs…
Hi @Gez !
We received also your email!
Let’s continue our conversation there!
Hi @Tania , I’m now having similar issues with the Sender integration, any chance one of the team could help? Thanks
Hi @Gez
I see that you’re under the Free plan, it allows 1 Branch, 1 Integration, and up to 3 different file formats. Please check whether you’re not exceeding this limit.
I also noticed that last time with Mailjet the issue was not with the connector itself but with the API key. I’d recommend reviewing its configuration or any restrictions to ensure everything is set up correctly.
Hi @Dima,
Yes, I have only 1 integration, I deleted the other one. I’m not exceeding this limit.
Last time, the issue was not strictly to do with the API key but to do with what type of API key Crowdin accepts (it doesn’t accept subaccount API keys - though this not mentioned in the documentation).
Anyway, everything is set up correctly, the problem is that Campaigns come through fine, but transactional email campaigns don’t. Is this another undocumented limitation?
Thanks
Gez
Yes, correct, due to some API limitations only Campaigns are supported.
Are the limitations on the Crowdin API or the Sender API? I’m just trying to work out who I should ask to address this limitation?
I’ll double-check with the team and let you know about it
I checked with the team and currently Sender does not have an API for transactional emails.
We will be happy to add it to the integration if Sender implements an API for transactional emails.
Thanks @Dima,
That’s exactly what I was after. Very much appreciated.
Hi @Dima, I’m trying to coordinate this collaboration. What’s the best email for Sender to use, in order to work with Crowdin on this?
Thanks
Gez
Hi @Gez as far as i can see, they have this form for customer support
Thanks @Ira! Though, I’m asking on behalf of Sender for the best email to use to get in touch with the Crowdin developers.
Hi @Gez
Thank you for clarifying, and I apologize for any misunderstanding!
Could you kindly ask the Sender team to contact us at support@crowdin.com? We will ensure their request is forwarded to the appropriate department.
Hi, I’m just wondering if I can speak to anyone about the Sender integration. I’d really like to get up and running but the issue that i reported a while back still isn’t resolved. I’ve spoke to Sender and they say they’re waiting on Crowdin for something, is there anything I can do to help move things along?
Hi @Gez
Please ask the Sender team to follow up, as I don’t see any conversations with them as well as my colleagues don’t have open conversations with them
