Hello! I use Android SDK and every time when I open my app I should login in Crowdin. Can we skip this?
Hi! That’s strange, we use Crowdin for over-the-air, and it works great without login. As I know their SDK supports some other features like real-time preview and maybe the login is needed for them. If it’s your case you may turn off it and check if the login is still needed
