In the Language Codes support article en-AR is listed as the code for English, Arabia. This incorrect, as AR is the ISO code for Argentina.
Hi @surfdude29 ,
Thank you for your suggestion! The code for the Arabic language is also ar, thus the English, Arabia language will have the en-AR code. However, you are always welcome to create your custom code or even language for your Crowdin project.
