Key is appended to context (when importing a CSV file)
I imported the csv file in Crowdin.
I am not sure why the app is appending key to the context string. My CSV file doesn’t have key appended to context. How to fix this issue? See the screenshot below:
Thanks for help.
Hi @manobal,
The system duplicates the identifier/key in the context field, this is just such a display on the platform. But don’t worry, on the file export you won’t have this in the Context column if you have one🙌🏻
