Hi! I recently ran into an issue with plural localization in Crowdin. I have something along the following in my source JSON:
"gameCount": {
"one": "{{count}} Game",
"other": "{{count}} Games"
However, I do not get any plural options in Crowdin, as I have seen other users have. Any tips appreciated! ^^
Dima
June 8, 2025, 5:07pm
2
Hi @RichardKanshen
The default JSON doesn’t support pluralization
Maybe try uploading it as i18next or go?
Translate Go JSON files into more than 300 languages using Crowdin. We support over 65 formats, including Android XML, iOS strings, XLIFF, and many others.
Translate i18next JSON files into more than 300 languages using Crowdin. We support over 65 formats, including Android XML, iOS strings, XLIFF, and many others.
Both work with plurals. For go, this should work well:
"cases": {
"one": {
"msg": "{Years} year"
"other": {
"msg": "{Years} years"
Or, alternatively, this one also should be working:
"cases": {
"one": "One book remaining!",
"other": "There are {N} more books remaining!"
Hi Richard! The issue is highly probable due to the file type setting. Please check your “Parser Configuration” under Project Settings for your JSON files. (as shown in the screenshot) Ensuring the file type is set to “i18next” is crucial, as this tells Crowdin to correctly interpret plural forms like “one” and “other.”
