Hi, those days my project started to disconnect from Github, like one after another, 3 in total. What can be the reason? I’ve set up integration a while ago using my manager’s token, never changed anything after connecting repositories.
@KateOlsen it’s ok, just re-login into system and re-set up integration (they would require you to log in with redirect into github if you use profile-based login).
I’m sure (99.99%) tokens you’ve used during setup just expired and that’s all.
