Hello, having an issue with integration.
In one of our projects, I’d like to use Bitbucket (we’re switching from Azure), so I tried to edit integration - connected the repo, and once I click the “save” button after configuration, there’s an error pop up or so.
What can be the reason? If needed I can send some screenshots.
              Hey @JessZavidy
Let’s try some magical wizard staff (in case I fail - pls direct message me with screenshots)
You haven’t accepted the service webhook from Crowdin in the repository admin panel.
Source path you’re using is not allowed or wrong (having conflict). A common mistake is having translation in the same please as source files, just at the same level - as a result,  for some files type system wouldn’t allow you to do so. Try adding a folder of something like that, so sources and translations be stored not at exactly the same level. For reference:
 Configuration File | Crowdin Documentation
Your subscription limits. I was working with the free plan for some time, this plan allows only 1 branch in Crowdin, so you cant save new integration unless you deleted (or changed it to a simple folder) a branch from the previous one (after Azure disconnect, your branch would still remain (unconnected, a stand-alone) in Crowdin Files tab)
Fingers crossed something would work
              @AnnaRockstray I guess Hogwarts should have invited you
Yeah, it was a combination of point 2 and 3. I’ve removed Azure branch and refer to guide with configuration file so it’s up and running now. You saved a lot of time for me, thanks!
