Is there a way to apply MT suggestions to all strings at once,
(not for each source string) in a file?
Hello @kozo.nishida
This should be possible by using MT pre-translation for all files in the project. Can be done as manual action or as part of workflow. Have you tried those approaches so far?
More info can be found here → Pre-translation | Crowdin Documentation
You’re always welcome. Most use cases are covered in our Knowledge Base, also there are a lot of useful extensions in the Store, you could check them in case you’re interested in extending project flexibility and used flexibility.
We support all popular MT engines, you’re welcome to choose the one that fits you the best:
