Have anyone faced an issue when integration Crowdin-Github is paused? Like, I don’t know the reason, I just see it paused like 2-3 times a week. Quite annoying. Can’t track this feature or bug, neither can understand the reason.
Integration can fail if you have the Push sources option enabled in your Integration Settings.
This happens when the source strings edited online did not have time to merge on your repo side
like user1 edited source string1 in Crowdin
no one approved that merge requests in Github
and the synchronisation already wants to push the old sources from your repo into Crowdin
So in order not to overwrite those online edits, Crowdin do stop the integration. You should receive a email each time this is happening. Maybe it’s in spam or your mailbox has limited email access.
You need to merge the existing changes on your repo.
