Integrate Chatgpt to Crowdin Editor
Hello
I have a question with how to integrate Chatgpt to my crowdin editor.
When I translate, my workflow is: copy source text to chatgpt com > ask chatgpt to translate > copy its answer > paste to crowdin editor
Is it possible to simplify the above process and make it a machine translation-like feature in the crowdin editor? I used my best efforts to configure the Machine Translation and AI Assistant tabs but it didn’t work the way I wanted.
Waiting for your help.
Regards,
Wayne
Hi Wayne,
Crowdin integrates with leading AI platforms, such as OpenAI, Google Gemini, Microsoft Azure OpenAI, and others, enabling you to utilize advanced AI-driven translations that take context into account at various levels. These translations can be easily applied to your content with just a few clicks through AI-powered pre-translation.
Furthermore, Crowdin’s AI features also serve as an assistant in the Editor, assisting with translation, proofreading, and more. Once setting up the AI prompt you can configure AI in the Editor prompt and suggestions from the AI will be visible directly in the Editor for each string:
You are welcome to configure AI and select the needed provider as described here:
Thanks,
