Ignore typescript / javascript import statments
Crowdin picking up the string in the import statement (…/…/types) and showing it in the translation, I want to hide it or ignore it, how can I do this?
import type { BaseTranslation } from "../../types";
const common: BaseTranslation = {
  SOMETHINGN_WENT_WRONG: "Ops, looks like something went wrong",
export default common;
Hi @MajorAmari !
You are welcome to hide the strings directly via the Sources tab as described in this article:
As a result, hidden strings will not be available for translation :slight_smile:
Thanks for replying!
This looks promising but, I wanted to automate this is there anyway to automate it?
It appears that automatically hiding a string might not be feasible. However, as a workaround, you could employ a processor to substitute it with something less easily translatable, such as a space
