Howdy. Have a problem and hope smone can help me. I have Crowdin Free sub, when I tried to connect master branch after removing development from the GitLab settings nothing happens. I didn’t get any error or something like that. Pls help, with respect, Josh.
@Josh As far as I know Crowdin Free plan has some limitations, one of 'em is the possibility to have only 1 branch (in Crowdin, it doesn’t matter if it’s manually created or integration brings it). I’d recommend you to replace all content from the branch (in Crowdin) into root or folder and delete the existing branch. After that everything should be ready for rock’n’roll and master branch connections. c
Cheers!
