HTML tags not parsed anymore
Hello
For 2 days now, the html tags in our Markdown files are not parsed anymore and removed from translation.
For example, we used to get this for translation :
<0>link</0>.
and now I get this :
[link](https://someurl.com).
I don’t know what changed, and couldn’t find any setting to change this.
Thanks in advance for any help.
Hi @emilise !
Please share with us the id of the project and the name of the file. Also please attach some screenshots on the matter which describe the appeared issue.
Thanks in advance!
Hello, the project is androidapsdocs, sample file docs/EN/Getting-Started/CompatiblePumps.md, but all the files modified in the last couple of days show the same issue.
Here is what I see :
Thanks!
Hi @emilise , as we can see, the string in Crowdin looks the same as in the source file. So the platform shows the same content that is in the source file
Hello, usually we get this kind of display, with placeholders instead of links :
Dear @emilise , could you please kindly send us the initial files before the upload (both with the correct display in Crowdin and incorrect) to support@crowdin.com?
