How to translate different branches at the same time?
If we have 2 branches: feature_A и feature_B, then how to translate them?
Do I understand right that the developer should only add source terms to its file in corresponding brach? Meaning that the file is unique, but only branches in gitlab are different?
Hi Katerina,
Well, it depends. Is content the same within them?
If yes, try using “Duplicates” (project settings → duplicates). In this case, once you translate something in Branch A, the same content in Branch B will automatically share the suggestions.
If the content is partially the same, I’d recommend Translation memory pre-translation (check the workflows section, better to have it automated).
If the content is very different, you can translate both branches as you wish, for example, one by one, or simultaneously.
