Hi, I thought there would be a setting for max length, just like context, but I didn’t find it. Please help, thanks.
@RocyMa
You can set the max length for translations by going to the editor, clicking on String Settings (the three dots at the top), and then selecting Max. Length.
what if we have different character limits for different rows?
Hello @RocyMa!
Currently, there’s no option to set Max. Length via the Multi Translation Columns tool, only if you upload and configure the spreadsheet via UI.
I passed this to our developers, and we should be able to add this option soon.
Hi @RocyMa,
We are happy to inform you that the Max.length option was added to the Multi Translation Columns app!
(Simplified Multi-Column Spreadsheet Translation: Try Our Crowdin App)
