hi, sorry for not very clever question, but unfortunately I can’t get the translation path right, here is my case
I have a raw folder that I have raw translation keys. I extract any new key in my app into that folder. (red box)
I want to configure corwdin to put the translations into another folder (blue box). so my key extractor can clean up the raw folder easily and create keys from scratch
my issue is, the translation includes all the folder from the root, I don’t want the raw to be included in here in the path. I want anything inside the raw folder. but I can’t figure it out how to get only content of a folder
if I use %original_path% it will have raw as part of the path and if I don’t use it, it won’t create nested folders (like welcome).
in my example the root of the folder is i18n. imagine root of the folder was /app/app-name/src/lib/assets/i18n/.
I will end up with a translation in /en/app/app-name/src/lib/assets/i18n/.
then how the translation branch (‘i18n_main’) could merge with the main branch. we are simply writing into another folder structure different from main branch
you see where it goes wrong? I can’t manage where the translation goes. sure I can write custom scripts to copy the translations into different folders but that’s a path that I prefer not to go and let the branch merging solve the conflict.
I should be able to set the root for the source. but I can’t find any setting that let me to configure it. now always the root of the source is / and any folder structure from there is copied until the end of the node. which doesn’t make sense. if I set the destination folder as same as the folder that source files are, just for purpose of having the source and translation in one folder I end up with a path like this
and being specific isn’t an option, I can’t be specific for 100 files that could be updated/deleted/renamed on daily basis. that’s why we are using glob, isn’t it?
but I came up with this solution on pure luck. there was no reference about this in the documentation and I was just playing with things and saw this finally worked. I didn’t understand why ** work different than the %original_path% and why %original_path%create a separate folder while ** merge the folder structure from root folder.
