How can I modify Github integration synchronization schedule? there are few option, the shortest is 10 minutes, but I’d like to have it to be 2-3 minutes. How to set up it?
No way, 10 minutes is the shortest limit. Allowing it to be more would probably cause everyone has synch once in 5 seconds and system drop down ![]()
If you want shorter time, only Github actions will work for this case
