our company uses a private gitlab setup with our own SSO login. so how to integrate with Crowdin? as in the gitlab integration, I do not see such an option.
Looks like Enterprise feature
SSO is available in a self hosted Gitlab, if so, than it’s definitely the Enterprise one. You need to make an upgrade or use CLI/API instead.
If you’re in open source plan, than private repo doesn’t available at all.
I see. got it. thanks! will look into the crowdin CLI option.
