Hello! Is it way to hide folders? It shows the full structure of my repo and I don’t like it - would prefer my translators see only the files for translation
Hope there is a way to achieve that
You can try adding preserve_hierarchy: false to your configuration file. In this case, the integration will place files from your repo into the version branch without showing your folder structure.
