Hi, I’m using a specific workflow, which means sometimes I include text that should be translated into variable brackets […]
Seems Crowdin detects everything, if it’s a 1 work, inside [] as a variable, not depending is it a 1-2-3 character like [%kz] or for example [London]
So, my question, how make words in this brackets translatable? Thanks.
