Hi. We’ve been using Crowdin for a long time for our open source projects, now we have 12 projects and feature “TM sharing” enabled. But I’m facing a lot of old suggestions, or suggestions from other projects that are not as good as their “brothers and sisters”. Is it possible to clean 'em up and see only the latest records there? Any answer will be appreciated, thanks
Hi there. Looks like it a common issue for the old projects
You can clean your TM in the Resources tab and then I also found cool apps developed by Crowdin tech pioneers. Personally I like 2 of them both:
- the TM cleaner (to erase all of old staff from TM) - Discover the right solution to enhance Crowdin experience
- and TM Generator (to create 1 nice TM and just upload it for another project usage)- https://store.crowdin.com/products/tmg
You’re welcome bro
